How to convert Named selection Mesh Nodes to faces?
    • ahm.eltaweel
      I have a named selection of mesh nodes and I want to convert it to faces.nI used named selection worksheet to achieve this target; however, once I click Generate nothing is created!n
    • Dragana Jandric
      How did you create that mesh nodes named selection at the first place? We usually create nodal named selection from geometry named selection. n
    • ahm.eltaweel
      I created it using worksheet by converting faces to mesh nodes.nHowever, I exported the CDB file then imported it again to another identical model.nThen I tried to convert the mesh nodes back to faces but it doesn't work!!!n
    • Dragana Jandric
      We cannot create geometry from nodes or elements.n
    • ahm.eltaweel
      The facets are already existed as a geometry and the mesh nodes are registered on a set of these facets. Is there any way to quickly convert (i.e using the mesh nodes as a guidance) the cloud of mesh nodes to set of facets?n
Viewing 4 reply threads
