May 24, 2022 at 8:59 am
Divyanshu
SubscriberI'm trying to copy an excel file from one folder to another and for this I'm trying to use shutil and os libraries. But, when i run the code through Mechanical ACT editor, it throws a Traceback error while importing. However, this works fine while using the shell in the Mechanical. I'm concerned about if these libraries are accessible in IronPython module or not. If not, how can we copy the file through other library.
May 25, 2022 at 11:01 am
Aniket
Ansys EmployeeCan you please share some more information? Which commands are you using?
-Aniket
3744
2573
1821
1236
594
