September 6, 2023 at 3:15 am
Maimuna Nagey
SubscriberI get this error message "lsf line 17: in expression A(i,...) = B the indices of A were out of range" when running this line of codes;
#loop over 8 equal intervals
phase_PB_v = matrix(1,8);
for (i =1:8){
switchtolayout;
select("TiO2_unitcell");
set("first axis", "Z");
set("rotation 1",(i-1)*180/7);
run;
Ex = getdata("phase", "Ex");
Ey = getdata("phase", "Ey");
E_L = Ex - 1i*Ey;
phase_PB_v(1,i) = unwrap(angle(E_L));
n = linspace(1,8,8);
plot(n,(phase_PB_v - phase_PB_v(1,1))*180/pi, "n", "phase", "phase scan");
I intend to calculate the phase with each angle of rotation of the unit cell.
- Error on Lumerical device
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Lumerical – error message when trying to open from Linux terminal
7592
4440
2953
1427
1322
