Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
How to create a B field using some custom equations?
    • SadiaSohid
      I am using a PCB trace in 2D simulation (Eddy current solver) with a 25A current to observe the B field. I want to plot the difference between the B field generated at different frequencies. Like
      B field magnitude at F = 1e-8 Hz
      B field magnitude at F = 1 MHz
      B field magnitude at F = 10 MHz
      Custom Equation to plot -
      I want to plot the following equation in the same plot -
      L1 = (B field magnitude at F = 1e-8 Hz) - (B field magnitude at F = 1 MHz)
      L2 = (B field magnitude at F = 1e-8 Hz) - (B field magnitude at F = 10 MHz )
      Can anyone please reply as soon as possible? Thank you!
    • HDLI
      Please review the KM in customer portal, How to visualize differences between the field plots?, https://support.ansys.com/KnowledgeResources/Solutions?solutionIdentifier=sol2046348&productName=ANSYS+Maxwell&productFamily=Electronics
      HDLI
