July 18, 2019 at 6:42 am
Nishanth
SubscriberI want to create a flapping motion for a wing on fluent. similar the link attached below, but not that complicated, I just want it to go up and down with the same angle of attack.
https://www.ansys.com/blog/dragonfly-flapping-ansys/
This is the model I have created, it has a enclosure and a rotating wall which contains the wing.
The mesh has a max skewness of 0.89
Lets say I want the wing to go from -60 degrees to +60 degrees, how do I do that?
Should I do this with dynamic mesh or use mesh motion in cell zone conditions?
I have never used UDF, can you please guide me from start on how to simulate the above mentioned motion?
July 18, 2019 at 8:48 am
Ansys EmployeeIf it's a simple rotation then you can use sliding mesh and rotate the cylindrical zone. The input is a rotation speed so you may need to use the expressions in 2019R2 to control the position/angle.
July 18, 2019 at 8:57 am
Nishanth
But when I give rotation It is going to rotate in one direction (clockwise or anticlockwise), I want it to go upto a certain angle and then it should start rotating in the other direction. Similar to a bird flapping!
December 23, 2019 at 12:19 pm
DucNguyen
Subscriberdear Rwoolhou
Where can I find this expresstions?
I'm trying simulation the flapping wing. I set up the wing flap down. when it at the bottom, I stop caculate and change the direction of rotation and repeat
sorry for my English
December 23, 2019 at 3:43 pm
Ansys EmployeeExpressions are in Fluent 2019Rx (I'd advise using R3, current release). Alternatively you'll need a UDF for rotation speed/direction.
3812
2593
1849
1244
600
