March 21, 2021 at 12:45 am
syed123
SubscriberHello
I have one fluid region which encloses the Turbofan, however, i have put an extra fluid region closer around the turbofan with a lot more mesh.
The problem i face is that i am not sure what the boundary condition should be for the fluid region inside the other fluid region. (both fluids are air and the one inside the other fluid has more elements - more mesh). Any help would be appreciated.
Regards
March 22, 2021 at 4:23 amKeyur Kanade
Ansys EmployeeFor conformal mesh you will need to subtract that smaller fluid volume from bigger one in SpaceCLaim. THen you will need to use share topology. You can also consider using BOI option in meshing. nPlease check following videosnnAnsys Meshing Share Share,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynViewing 1 reply thread- You must be logged in to reply to this topic.
Trending discussions- ANSYS Workbench Measuring within Design
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2564
2080
1299
1106
459
