How to create a named selection of Vertices in Workbench using scripting & .txt file of XYZ Coordin.
    • ahm.eltaweel
      I have data of a cloud of vertices in the form of X, Y, Z coordinates in .txt formatnnHow to use scripting in WorkBench to import, read, and create a named selection out of the .txt file.nnI am new in scripting in workbench, any suggestion for the structure of the required code?n
    • Aniket
      In which software you intend to create the named selections? Although providing scripts is out of support scope for ANSYS employees on student community, may I ask you to take a look at:nWhich should have examples, developers guide available. nYou can also check help links at:n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumn
    • ahm.eltaweel
      Thank you for your feedback.nI am looking to create these named selections in Ansys WorkBench Mechanical.nI will check the resources you proposed. n
