November 10, 2020 at 10:29 pm
jacobier
SubscriberI need to create a 2D model with two rectangular plate attach to each other. After I create one rectangle sketch. Whenever I add a rectangle, it always go into the previous sketch. How can I make a new sketch in the same plane? I could not find it.n -
November 11, 2020 at 11:45 am
November 12, 2020 at 3:39 pm
jacobier
SubscriberThank you very much! I wonder why it is not put in the right click manual. It is really hard to spot.n
- The topic ‘How to create a second sketch in Design modeler’ is closed to new replies.
- pcb
- No longer possible to import f3d with 2023?
- line bodies and surface body shared topology
- How to chang unit in Ansys Discovery 2023?
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- SpaceClaim Script: Selection by FilterByBoundingBox
- Assignment of revolute joint
- Max/min over time results in AIM
- Axisymmetric model – Rubber seal
- To change language in Ansys Discovery
8808
4658
3155
1688
1480
