July 4, 2022 at 5:00 pm
hansongriggs
SubscriberHi there. I would like to create a uniform magnetic field in a 3D box region of space that varies with time.
With the Maxwell Magnetostatic solver, I can use a combination of 'Tangential H-Field' and 'Zero Tangential H-Field' boundaries to create a uniform magnetic field (see
for details on how this is done). See attached image to see this:However, I would like the uniform magnetic field to be time-varying, meaning I need to use the 'Magnetic-Transient' solver. I want to be able to "pulse" the magnetic field. For example:
- from 0-2ms the magnetic field is zero;
- then between 2ms-10ms the magentic field is 10A/m;
- then between 10ms-20ms the magnetic field is zero again.
Is this possible in the Maxwell Magnetic Transient Solver?
July 20, 2022 at 7:22 am
Navya C
Ansys EmployeeHi @hansongriggs,
I don't think it is possible to achieve. Because the field won't go to zero immediately after the source goes to zero.
May I know why you want to do that and what are you trying to achieve here?
Navya
Ansys
- Maxwell, HFSS or Q3D?
- Error
3740
2570
1785
1236
594
