How to create a valid path in I Beam.Please help to remove this error. Cam someone help me with this
    • Umarfarooq46
    • peteroznewman
      nDelete the item in the outline with the ? under the Solution branch.nWhat do you need a path for? What are you trying to plot?n
    • Umarfarooq46
      i want to run analysis on i beam.n
    • peteroznewman
      Delete the Linearized Equivalent Stress plot and the analysis will run.n
Viewing 3 reply threads
