November 6, 2018 at 8:19 pm
November 6, 2018 at 9:51 pm
SubscriberYou can draw two diagonal lines that intersect at the center. That will make a vertex. Or you could draw a small circle on the green face and that will make a new face that you can pick to assign a "point" load.
Peter -
November 6, 2018 at 10:17 pm
November 6, 2018 at 10:23 pm
sameerfares
SubscriberSorry Peter! Circle did show up after i closed the file and reopened. I thought i did refresh all data in Mechanical and updated geomtery in spaceclaim but i didnt see it then. Is there something else i shouldve done to update the geometry?
Thanks,
Sam
November 7, 2018 at 1:40 am
SubscriberSam,
If Mechanical is closed while you are editing the geometry in SpaceClaim, exit SC and WB will show a Refresh is required. You can click the Refresh button, or just open Mechanical and the geometry will update.
You can have both SC and Mechanical open and after you edit geometry in SC, in Mechanical, RMB on Geometry and select Update Geometry from Source and it should attach the new geometry.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2688
2138
1351
1136
462
