July 31, 2019 at 1:50 pm
sadaspire
SubscriberI am trying to run a FSI simulation using the system coupling set up in the Workbench. In order to speed up the sim, I plan to use the HPC but I have been struggling to create a journal file from the Workbench. Below is what I created so far using automatic creation. Could anyone know how to write the journal file for the system coupling in Workbench? Thank you for your help in advance.
# encoding: utf-8
# Release 18.1
SetScriptVersion(Version="18.1.463")
template1 = GetTemplate(TemplateName="System Coupling")
system1 = GetSystem(Name="FFF")
system2 = template1.CreateSystem(
Position="Right",
RelativeTo=system1)
setupComponent1 = system1.GetComponent(Name="Setup")
setupComponent2 = system2.GetComponent(Name="Setup")
setupComponent1.TransferData(TargetComponent=setupComponent2)
system3 = GetSystem(Name="SYS")
setupComponent3 = system3.GetComponent(Name="Setup")
setupComponent3.TransferData(TargetComponent=setupComponent2)
setupComponent1.Update(AllDependencies=True)
setup1 = system1.GetContainer(ComponentName="Setup")
setup1.SendCommand(Command='(cx-gui-do cx-set-list-tree-selections "NavigationPane*List_Tree1" (list ))')
setupComponent3.Update(AllDependencies=True)
setupComponent2.Refresh()
setup2 = system2.GetContainer(ComponentName="Setup")
AnalysisSettings1 = setup2.GetAnalysisSettings()
AnalysisSettings1.EndTime = "500
AnalysisSettings1.StepSize = "0.5
dataTransfer1 = setup2.CreateDataTransfer(Name="Data Transfer")
dataTransfer2 = setup2.CreateDataTransfer(Name="Data Transfer 2")
participant1 = setup2.GetParticipant(Name="Solution 1")
dataTransfer1.SetEntityProperties(Properties=Set(SourceParticipant=participant1, SourceRegion=None, SourceVariable=None))
region1 = participant1.GetRegion(Name="fsi")
dataTransfer1.SetEntityProperties(Properties=Set(SourceRegion=region1, SourceVariable=None))
variable1 = GetDataEntity("/Setup 2/SystemCouplingVariable:force")
dataTransfer1.SetEntityProperties(Properties=Set(SourceVariable=variable1))
participant2 = setup2.GetParticipant(Name="Solution")
dataTransfer1.SetEntityProperties(Properties=Set(TargetParticipant=participant2, TargetRegion=None, TargetVariable=None))
region2 = participant2.GetRegion(Name="FSIN_1")
dataTransfer1.SetEntityProperties(Properties=Set(TargetRegion=region2, TargetVariable=None))
variable1 = GetDataEntity("/Setup 2/SystemCouplingVariable:FORC")
dataTransfer1.TargetVariable = variable1
dataTransfer2.SetEntityProperties(Properties=Set(SourceParticipant=participant2, SourceRegion=None, SourceVariable=None))
dataTransfer2.SetEntityProperties(Properties=Set(SourceRegion=region2, SourceVariable=None))
variable1 = GetDataEntity("/Setup 2/SystemCouplingVariable:INCD")
dataTransfer2.SetEntityProperties(Properties=Set(SourceVariable=variable1))
dataTransfer2.SetEntityProperties(Properties=Set(TargetParticipant=participant1, TargetRegion=None, TargetVariable=None))
dataTransfer2.SetEntityProperties(Properties=Set(TargetRegion=region1, TargetVariable=None))
isplacement")
dataTransfer2.TargetVariable = variable1
intermediateResultFilesOutputControls1 = setup2.GetIntermediateRestartDataOutputControls()
intermediateResultFilesOutputControls1.OutputFrequency = "StepInterval"
intermediateResultFilesOutputControls1.StepInterval = 5
August 2, 2019 at 10:28 am
sadaspire
SubscriberHi Peter,
Thank you for your reply.
Please find the attached Workbench project file. It would be appreciated to give me some advice.
Cheers,
August 2, 2019 at 10:48 am
SubscriberSorry, I can't help. I have never used journal files.
2120
1347
1118
461
