November 13, 2020 at 3:06 pm
SaiD
Ansys EmployeeHow do I create an isosurface at the boundary layer edge in EnSight? Thanks!n -
November 13, 2020 at 3:08 pm
RK
Ansys EmployeeHello, nSelect the wall part and open the Calculator. Use the BL_Thick function. This will create a scalar on the wall part equal to the boundary layer thickness. n Select the wall part. Go to Create > Elevated Surfaces. Choose BL_Thick as the variable and set the scale to 1.n
- The topic ‘How to create an isosurface at the boundary layer edge in EnSight?’ is closed to new replies.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- obtaining pressure distribution by making points in ansys
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
8808
4658
3155
1688
1478
