January 27, 2022 at 7:13 pm
Anadi_Mondal
SubscriberHello,
The process for circumferential average is as follow:
January 28, 2022 at 2:08 pmKarthik R
AdministratorHello I'm not sure if I understand your question completely. Could you please add some images and help me understand your ask better?
Karthik
January 28, 2022 at 4:39 pmAnadi_Mondal
My tube is 1.97m long. When I am trying to get the circumference average of film thickness, I am creating 195 bands along the axial direction of the tube. After getting the thickness, I notice band location (red line mark) starts from a small distance away from the inlet and some distance before the outlet. But I need to get data (thickness) at the inlet(blue marked line) and outlet(blue marked line).
Please see the below image:
Here the band is creating at the red marked line and giving data at these points. But, I need to create a band and get data at the blue-marked location. Actually, the red line is the cell center. How can I create a band at the blue-marked location? Or, how can I control band locations?
If still my explanation confuses you, please let me know.
Thanks Anadi
January 31, 2022 at 2:27 pmRob
Ansys EmployeeGiven the value at that position will be entirely dependent on the boundary condition I'm not sure it'll be much use. Similarly, with an aspect ratio like that I'd be wary of using any of the results.
January 31, 2022 at 5:38 pmAnadi_Mondal
SubscriberSorry ! I did not get you.
Here is my situation:(the image is for circumference averaged film thickness)
My annular tube extends from 0.1m-2.07m. While I am creating 200 bands to get the circumference averaged value at the band locations, the first band (location)starts at 0.105051m. But I need to create the first band at exactly 0.1m. Is it possible to or how can I create a band at 0.1m and get data at this position?
Thank You Anadi
Viewing 4 reply threads- You must be logged in to reply to this topic.
3648
2534
1745
1226
578
