3D Design
3D Design
How to create connections between the Solid and Fluid domain
    • ashiadarsh
      For conjugate heat transfer problem i split the body into two- solid and fluid in import the model into  design modeler..for creating connections between the two whether I should choose FLUID as frozen or should I opt share topology?
    • Keyur Kanade
      if you want conformal mesh between solid and fluid then please select bodies - right click - create a new part.
      in this part properties, make sure you have 'share toplogy' operation set to 'automatic'.
      if you want non conformal mesh between solid and fluid then create different parts for solid and fluid.
      if this helps you, please mark this post as 'is solution' to help others on forum.
    • ashiadarsh
      Sir can you please explain the difference between conformal and non conformal mesh?
    • Keyur Kanade
      check this.
    • ashiadarsh
      Thank you...that video was very helpful
Viewing 4 reply threads
