how to create damping force on roll and yaw vehicle?
    • Beni
      i want to search the damping force if my vehicle in roll or yaw condition
    • Keyur Kanade
      are you using fluent?
      you may want to use 6dof capability.
      please look at following video to get idea about 6dof.
    • Beni
      Thank you kkanade
      yes I am using fluent
      I want to use fluent to get drag coefficient of ROV in 6dof, but I get trouble when search pitch, roll, and yaw
    • Keyur Kanade
      you can check following. also please insert some images and describe issue in details like mesh images, images of set up etc.
    • Beni
      thanks for your suggestions
      I am started using mrf, but any warning appeared in generate mesh and I cant solve it, would you like help me
    • Beni
      info : warning
      text : element volume exceeds the warning limit. small element volume was encountered.
      association : project>model>geometry>inner-zone>inner-zone
      info : warning
      text : inflation created stairstep mesh at some locations.
      btw why I cant insert image in this discussion?
Viewing 5 reply threads
