September 3, 2018 at 1:32 pm
Karthik K R
Subscriberhow to create a domain of density stratified water in ansys fluent using open channel method
September 3, 2018 at 1:34 pm
DrAmine
Ansys EmployeeMoving the thread into the Fluid Dynamics? Can you elaborate more on your concern?
September 3, 2018 at 1:56 pm
Karthik K R
SubscriberI want to simulate movement of an object under water (sea), using multi-phase VOF method and open channel initialization. so i want to incorporate density stratification like in the actual sea
Thanks..
September 3, 2018 at 2:59 pm
DrAmine
Ansys EmployeeYes you can do that with VOF and Open-Channel Flow but I do not understand the density stratification: Do you mean the density stratification Air/Water or the Density change of water due to temperature/pressure/salinity/depth..?
September 3, 2018 at 3:57 pm
Karthik K R
SubscriberThe 2nd one,Density change due temperature.. and how can i implement the the temperature difference in open channel..
Thanks.. -
September 3, 2018 at 6:20 pm
DrAmine
Ansys EmployeeIf you define the density of water as temperature dependent then you will obtain a density stratification for the water. How to setup an open channel case can be checkedin Raef''s Tutorial :
September 14, 2018 at 2:49 am
Karthik K R
SubscriberI know that density can be defined as a function of temperature. But how can i introduce that temperature difference to the water channel in my simulation
Thanks -
September 14, 2018 at 8:41 am
Ansys EmployeeYou mean you want to change the temperature with depth? You'll also need to set the inlet, and there are a few threads on here explaining the DEFINE_PROFILE UDF macro.
2600
2088
1319
1108
459
