January 3, 2022 at 4:16 pm
Hassanbutt
SubscriberI have final year project on "Effect of Dimples on airfoil". But i could not able to find any helping material regarding creating dimples on airfoil. Please guide me how to create Dimples on airfoil. It will be much appreciated.
Thanks in advance.
January 3, 2022 at 6:32 pmpeteroznewman
SubscriberDimples can be made by creating an array of spheres and subtracting them from a solid body. In the image below, you can see a set of spheres that interfere with the solid rectangular block below them.
Here is the solid block after the Combine operation has cut the spheres from the block, leaving behind dimples.
February 24, 2022 at 10:57 amMadhu24
SubscriberHi there, I tried to generate an array of spheres on the airfoil surface. But after adding them there is no increase in the solid bodies in the tree diagram. As a result when I was trying to subtract I was not able to select tool bodies and target bodies. Please help me in resolving this. Thanks in advance
February 26, 2022 at 6:10 pmpeteroznewman
SubscriberCreate a new component to make the array of spheres. Then copy in a solid body of wing to do Combine function.
Trending discussions- ANSYS Workbench Measuring within Design
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2524
2066
1279
1096
457
