April 13, 2023 at 9:19 am
Sekhar Babu
Subscriberhow can i create a new materila details in my library
April 13, 2023 at 1:31 pm
Nanda Veralla
Ansys EmployeeHello Sekhar,
Please see if the following link helps.
Create Material – ANSYS Innovation Courses
Nanda.
April 13, 2023 at 2:14 pm
Akshay Maniyar
Ansys EmployeeHi Sekhar,
The link shared by Nanda will be really helpful. If you have an XML file of any material exported from some other project, you can also import it using the 'Import Engineering data' option.
Thank you,
Akshay Maniyar
- How do I make a chart with multiple material parameters on y-axis?
- Invalid Assignment error
- *LOCAL COORDINATE SYSTEM ANSYS APDL ? how Ansys transform coordinates system?
- Material library
- PLA Material
- How to add SN curve for new material in Fatigue analysis?
- ANSYS 19.0 with Additive Manufacturing Extension
- properties of balsa wood
- Looking for Spring steel (55Si7) library material
- Ansys material damage
5346
3345
2471
1310
1016
