June 9, 2022 at 4:18 pm
f.stapelfeldt
SubscriberHey, I'm trying to create a cutout in hfss 3d layout and i want to control the size with a variable. When i create a parametric object and subtract it from another object, the parameterization gets lost. E.g. if I have a slot with a width x and subtract this from a rectangle, after the operation, changing x doesn't change anything. -
June 9, 2022 at 4:27 pm
f.stapelfeldt
SubscriberDefining something as negative only kinda solves it, designing more complex shapes by adding, subtracting and intersecting is sometimes neccessary.
July 26, 2022 at 4:48 pm
Charlotte Blair
Ansys EmployeeHi f.stapelfeldt,
Did you try the cutout BEFORE parameterizing it. This will allow you to parameterize the cutout.
Charlotte
Ansys
- Maxwell, HFSS or Q3D?
- Error
3744
2573
1821
1236
596
