August 22, 2019 at 1:41 pm
jlhee
Hey guys,
Do you know how to create partitioning line for local meshing sizing?
I have (imagine) a tube, that runs from 0 to 100 mm. Downstream of the tube is a component or something, my fluid zone before the slicing face has no partitioning line along the axial length!
How do I have at least 4 lines each 90 degree apart so I can have local mesh sizing?
Thanks.
J -
August 28, 2019 at 12:26 pm
Ansys EmployeeYou can split the surface in the geometry tool.
August 30, 2019 at 11:02 am
jlhee
SubscriberThanks rwoolhou, I will look into it.
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2524
2066
1279
1096
459
