November 3, 2018 at 4:52 pm
rajdipjag
SubscriberHOW TO CREATE PLANE IN RESULT FILE OF ANSYS FLUENT WHEN PHYSICAL DOMAIN IS 3-DIMENSIONAL.
November 5, 2018 at 11:07 am
Ansys EmployeeI tend to use an isosurface of mesh and then set to x, y or z values to suit my needs. If you open up mesh, contours or vector panels it's under the New Surface menu. I'd also suggest going though the tutorials as it should be covered there.
November 6, 2018 at 9:06 am
Keyur Kanade
Ansys EmployeeYou can use Post processing - create - isosurface. Please select Mesh and then select x, y or z direction
2688
2138
1349
1136
462
