How to create sliced plots to visualize changes in a variable over a distance using Ansys Workbench?
August 21, 2019 at 8:47 pm
ravichsj
SubscriberHello Ansys users,
I am working on a project in which is in correlation with acoustic imaging using Ansys Workbench. I applied a planar acoustic pressure field on one side of the model and obtained the results for total deformation. I want to create a sliced plot to visualize the changes of the deformation over a distance. I have observed that this is possible using COMSOL Multiphysics software. I want to obtain the same in Ansys Workbench. I have attached the model for your reference. I have also attached the sliced plot result of some other model which was done by COMSOL for further understanding. Thanks in advance! -
August 22, 2019 at 2:45 pm
HuiLiu
Ansys Employeecreating a "section plane" lets you look at the result at certain cross section. does that work for you?
August 29, 2019 at 4:13 pm
ravichsj
SubscriberThat should suffice. Thanks a lot!!
2088
1319
1108
459
