March 12, 2021 at 12:51 pm
Dhanushspace
SubscriberI am facing problem on capture the mesh in winglet tip and unable to maintain the angle in winglet to far-
March 12, 2021 at 3:08 pmRK
Ansys EmployeeHello, nAs Ansys employees, we will not be able to download any attachments. Can you please insert an image instead and that will enable us to assist you better. Thanks! nMarch 12, 2021 at 3:11 pmDhanushspace
SubscriberThank you for your reply sir,nI inserted images also sir.nMarch 12, 2021 at 3:14 pmMarch 12, 2021 at 3:14 pmMarch 12, 2021 at 3:15 pmMarch 12, 2021 at 4:20 pmMarch 15, 2021 at 4:19 amKeyur Kanade
Ansys EmployeeIt would be very difficult to identify issue at the wing tip just by looking at the images. As ANSYS Staff, we can not download attachments. nOthers can pitch in and check your geometry to give suggestions. nThere are few videos on ICEMCFD blocking on net. You can go through those videos. Creating block mesh for such geometry is very time consuming. You may want to check tetrahedron method in Ansys meshing along with inflation. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student CommunitynViewing 7 reply threads- You must be logged in to reply to this topic.
Trending discussions- ANSYS Workbench Measuring within Design
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2524
2066
1279
1096
457
