August 26, 2018 at 2:02 pm
August 26, 2018 at 2:05 pm
DEBA
The following code is ok sir?
#include "udf.h"
#define mu_p 0.00123
#define H_ct 0.48
#define k_0 3.96
#define k_inf 1.71
#define gamma_c 5.0
DEFINE_PROPERTY(cell_viscosity,c,t)
real shear_rate;
real mu;
real k;
real sqrt_gamma_ratio;
shear_rate = C_STRAIN_RATE_MAG(c,t);
sqrt_gamma_ratio = sqrt(shear_rate/gamma_c);
k = (k_0+k_inf*sqrt_gamma_ratio)/(1+sqrt_gamma_ratio);
if (y<50)
mu = mu_p/pow((1-0.5*k*H_ct),2);
else
mu=0.00345
mu=return mu;
August 26, 2018 at 4:25 pm
Karthik R
AdministratorHello,
Were you able to compile this code? Did you get any errors? Could you please share your errors? One note: I do not think you have defined defined 'y' in your code.
As suggested by other experts, you should strongly consider looking into the DEFINE_PROFILE example in the customization manual. I am attaching a screenshot of the DEFINE_PROFILE here. Please go through similar examples for better understanding.
I hope this helps.
Best Regards,
Karthik
August 26, 2018 at 4:40 pm
Karthik R
AdministratorHello,
Also one additional note:
please refrain from creating additional threads to ask follow-up questions related to an earlier thread because of the following reasons:
- there is no continuity and you might receive repetitive answers from different sources.
- If somebody has a similar issue as yours and is trying to find an answer, it becomes difficult to follow the discussion as it is scattered over several threads.
Thank you.
Best Regards,
Karthik
September 4, 2018 at 7:51 am
DEBA
SubscriberSIR I HAVE WRITTEN UDF BUT SIR I AM GETTING error sir
ERROR IS fluent/14.0.0/src/dual_cell.h:line 1 : parse error.
September 4, 2018 at 9:00 am
DrAmine
Ansys EmployeeStop posting the same question everywhere please and bear in mind that this is an open community so everyone can have access into you UDF.
September 4, 2018 at 9:15 am
Ansys EmployeeParse error typically means you've got the syntax wrong. If it's a UDF from the manual check for white space characters (HTML & pdf often contain these), if you wrote it check line 2 too. I'm not entirely sure why you're trying to access the heat exchanger model, and would also recommend updating to R19.
2600
2088
1317
1108
459
