February 12, 2022 at 7:46 am
chandrabhan
SubscriberHello,
I am trying to create a 3d convex hull. The convex hull has 10 vertices and 16 surfaces. The VA command allows only 10 areas. How can I generate volume with more than 10 areas?
February 14, 2022 at 3:14 amKeyur Kanade
Ansys EmployeeCan you please explain more. Which tool you are using? Is it SpaceClaim?
Can you please insert some images and explain issue using those images.
Regards Keyur
February 14, 2022 at 6:15 amchandrabhan
SubscriberKeyur, thanks for your support. I am trying to create meso-model of concrete. The aggregate is shown in the image is currently areas and not volumes. I want to generate volume bounded by area regions. For this VA command is used but is limited to 10 areas only.
My problem is, I have more than 10 areas for an aggregate particle and the VA command is showing an error. So, the problem statement is "how can I
create volume enclosed by more than 10 surfaces?"
February 16, 2022 at 12:34 pmKeyur Kanade
Ansys EmployeeAs Ansys Staff, we can not download attachments. Please upload images using upload image functionality.
Regards Keyur
February 16, 2022 at 3:55 pmchandrabhan
My problem is, I have more than 10 areas for an aggregate particle and the VA command is showing an error. So, the problem statement is "how can I create volume enclosed by more than 10 surfaces?"
I am using ANSYS MAPDL.
Viewing 4 reply threads- You must be logged in to reply to this topic.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
3744
2573
1821
1236
594
