March 18, 2021 at 6:35 pm
tfirdous
SubscriberHi,nHow to cut a geometry in half on an axis or at an angle, in lumerical?nThanksnn -
March 19, 2021 at 5:00 pm
Guilin Sun
Ansys EmployeeHi, You can add another rectangle or other object, with larger number in mesh order, eg, lower priority. please refer nhttps://support.lumerical.com/hc/en-us/articles/360034915233-Understanding-mesh-order-for-overlapping-objectsn
- Error on Lumerical device
2706
2146
1357
1144
462
