How to deal with the error message about “You have specified result time (or frequency) = xxxx for a
October 4, 2017 at 12:20 pm
pgl
Ansys EmployeeThis error message indicates that the DISPLAY TIME under one of the results in the project exceeds the END TIME of the simulation. Thus, program is not able to plot the results. The DISPLAY TIME is the "specified time (or frequency)" referred in the message while the END TIME is the "maximum time (or frequency)" referred in the message. What user needs to do is to enter 0 at the DISPLAY TIME of the results. Program will re-set the DISPLAY TIME automatically to the END TIME. Thus the results will be plotted by the program and no such error message will appear.
Viewing 0 reply threads
Trending discussions
- How to deal with the error message about “You have specified result time (or frequency) = xxxx for a
- Can I define springs with coincident nodes defining each end? Can I use one spring element to define
- Check
- Any suggestions on speeding up convergence behavior with surface-to-surface radiation?
- If SCDM issues the message “Cannot open the document. Reason: Failed to load body geometry.” and the
- What is cause of error: display time for result item greater than the step end time?
- In a harmonic analysis, is the damping produced by MP,DMPR; TB,SDAMP; and DMPSTR constant vs frequen
- While projecting surfaces/curves onto cylindrical surfaces, the final shape sometimes deteriorates.
- How can I do a response spectrum analysis using more than 10,000 modes? The current solver limit is
- Why the section plane icon is grayed out in Mechanical windows ? How to make the section plane windo
Top Contributors
2524
2066
1285
1096
459
Top Rated Tags
