November 22, 2019 at 6:50 am
alucardz14
My problem description:
I'm trying to solve the problem about the interface between water and air in a microchannel.
Bubble is stayed at the cavity and water is injected through the inlet.
Surface tension force is dominant rather than inertia and viscous forces.
Numerical results:
Inlet velocity is 0.01 m/s.
However, The numerical results show that the spurious velocity of 0.2 m/s at the interface near the wall.
Please see the attached *.cas and *.dat files.
1) zoomed area (vectors of velocity components)
2) entire domain (contours of velocity magnitude)
Questions:
First, why a (non-physical) spurious current is observed when using the VOF method.
Second, how to reduce this spurious currents?
November 22, 2019 at 11:32 am
Ansys EmployeeYou may find refining the mesh and reducing the time step to work. Also have a look in the Release notes and documentation: there are some numerics that can help but I can't remember which version they're in.
November 23, 2019 at 12:12 pm
alucardz14
SubscriberThanks for your information. As far as I know, small time step with finer mesh can be the reason that spurious currents are getting worse. (Brackbill's aritcle, https://doi.org/10.1016/0021-9991(92)90240-Y)
I already did some simulations to check the effect of mesh and time step. It did not help with convergence and accuracy.
November 25, 2019 at 6:08 am
DrAmine
Ansys EmployeeYou are right.
You probably need to look into beta feature after interracial dissipation. Other trick is to increase the number of smoothing steps for surface tension (docu) -
November 26, 2019 at 4:19 am
alucardz14
SubscriberSome tests were performed by adjusting smoothing steps (solve>set>surface-tension options in the TUI).
The magnitude of the velocity was decreased by increasing smoothing step, however, the spurious currents (vortex) was maintained.
So, numerical results have still non-physical behaviors.
November 26, 2019 at 6:34 am
DrAmine
Ansys EmployeeTry the other suggestion too. Spurious velocity is an evergreen topic for all multiphase codes.
Make a sensitivity run without st force and with st stress instead of Brackbill force.
5360
3345
2471
1310
1018
