July 24, 2019 at 8:34 pm
July 25, 2019 at 10:32 am
SubscriberFile > SpaceClaim Options > Rendering Quality and enter a larger number, like 7.
Note: the arcs are geometrically perfect, this setting is just affecting the display quality. You could turn the rendering quality down and make the two curves look worse, but if you took them into meshing and meshed them with closely spaced nodes, the nodes would follow the true arc and not the rendered facets.
July 25, 2019 at 10:35 am
Ansys EmployeeIf you look in the SpaceClaim options under first menu change the rendering options and decrease the number. A better approach may be to copy & paste the line you have and then split it? Or just split it.
July 25, 2019 at 12:17 pm
joshuaehiz
SubscriberI see. Thanks a lot.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2564
2078
1289
1106
459
