February 8, 2023 at 2:47 pm
tandama
Subscriber -
February 9, 2023 at 12:38 am
Atharv Joshi
Forum ModeratorHi Tim Martinson ,
You can change default measurements to inch by navigating to "Settings" and changing "Model Unit System" to Imperial and "Length" to inch.
Also, you can change simulation unit system. Please refer to the attached image.
Thanks, and Regards
- pcb
- No longer possible to import f3d with 2023?
- line bodies and surface body shared topology
- How to chang unit in Ansys Discovery 2023?
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- SpaceClaim Script: Selection by FilterByBoundingBox
- Assignment of revolute joint
- Max/min over time results in AIM
- Axisymmetric model – Rubber seal
- To change language in Ansys Discovery
8808
4658
3155
1688
1478
