Tagged: ansys-fluent, boundary-conditions, cfd, fluid-flow, fluids
February 26, 2022 at 1:45 pm
Adityav1998
SubscriberI have made a model of a geometry and applied 10 bar pressure at the inlet with velocity of 0.0008 m/s but at results pressure drop to less than 1 bar , i want the fixed pressure at inlet 10 bar pls help
February 28, 2022 at 2:55 pmKarthik R
AdministratorHello:
Under the velocity inlet boundary condition, you can only set the Initial Pressure or Supersonic pressure. It does not set the pressure in any other case. If you wish to set pressure, you will need to use a Pressure Inlet condition.
Karthik
2706
2138
1355
1144
462
