How to define common temperature from a temperature profile
    • Adarshanand
      Temperture profile.
      We can see in the above figure temperature pattern.Starting from 49.1 deg c to 51.7 deg c. I need a common temperature to assign but, since this temperature is distributed over the profile in different pattern .I can't even assign them some average temp.
      Do you want to set a single temperature on an inlet? If that's the case why are you using a profile?
    • Adarshanand
      I want to find the outlet temperature actually
      Use a mass weighted average on the outlet: under the Results section of Fluent.
    • Adarshanand
      Yes it worked.
      Thank you rwoolhou.
Viewing 4 reply threads
