October 13, 2018 at 3:26 pm
aliBaratian
Subscriberhi every body
i have two concentric beams as in pic below:
the left side is fixed for both. the inner longer beam is forced down and i have defined the beams to be in "no separation" contact.
the problem is the inner beam penetrates and gets out of the tubular beam as in pic below !
can any one help me with this?
thanks in advance
October 13, 2018 at 4:17 pm
SubscriberInsert a Contact Tool into the Connections folder and Generate Initial Contact Results. Look to see if the contact is closed.
If not, edit the Pinball Radius on the contact and make it larger.
October 13, 2018 at 4:20 pm
Sandeep Medikonda
Ansys EmployeeBeam to beam contact underwent a major upgrade in 19.1.
Please post snapshots of the contact details you are using?
Sandeep
Best Practices to post on the Student Community
2068
1289
1106
459
