November 7, 2019 at 9:45 am
Firas
SubscriberHi all,
Can anyone help me with this problem, I am trying to design an unequal Wilkinson power divider using HFSS, I design it using circuit and everything is okay at the circuit level. My problem is when I design the power divider with HFSS I am not able to define the resistor port correctly some how. I dont want to use LumpedRLC boundary condition because I want to see the effect of changing the resistor value on the overall performance without running HFSS simulation for different LumpedRLC values .
So I need to link the HFSS design to a circuit and inside the circuit design I will assign a resistor and change it is value and see the effect on the S parameters of the power divider designed in HFSS.
In HFSS How to define the ports of the resistors ? Should it be lumped ? If so what should be HFSS solution type to define this port correctly? Also should we make the lumped port integration line going from ground to the port ? what should be the value of the port full impedance in HFSS , I mean I dont want to assign any value because it should come circuit can this work.
Any Help will be really appreciated.
Best Regards
November 14, 2019 at 3:00 pm
jtharp
Ansys EmployeeIf you go to File -> Open Examples -> HFSS 3D Layout -> Component you will see an example Wilkinson divider with an imported S Parameter file for the resistor (to capture any phase imbalance caused by parasitic capacitances of a thin film resistor). HFSS Layout is the easiest GUI to simulate these structures.
Have fun!
- Maxwell, HFSS or Q3D?
- Error
5454
3419
2473
1310
1022
