How to describe the shearforce-displace behavior in ansys workbench mechanical?
    • Guangqi
      I would like to simulate the tape deform behavior:
      die attached on tape and the tape will have a slight deformation when add the force on die. Which boundary condition should I use
    • Wenlong
      Hi Guangqi,
      You can apply a remote force on the die to model the shear tool (with the force location on the shear tool center). A force on the die to press it against the substrate. For the substrate, you can apply a fixed boundary condition to the bottom face.
      Wenlong
    • Guangqi
      Thank you for your reply Wenlong,
      What is the boundary condition between die and substrate? If it is bonded then how could the die move? If it is frictionless it seems not reasonable.
