August 8, 2023 at 4:01 am
Kawshik Nath
SubscriberI want to design exactly the structure given in paper but I can't there is a hole generate between this pyramidal array.
For designing a inverted periodic array 1st I have to made a unit cell of inverted pyramid array structure after that I create it's period. Please give me a solution how can i make this structure fully a resemble of that paper.
Figure given into the paper:
Figure which i draw to simulate
Perspective view
August 8, 2023 at 10:54 pm
Devika Padmakumar Nair
Ansys EmployeeHello Kawshik Nath,
Try not to duplicate same question or posts. posting progres /continuation question in same post will get a faster response. Please refer this Ansys Insight: Ansys Innovation Space —- Forum and Feed
Suggestions are provided in your original post as response:
How to design a period of hollow inverted pyramid? (ansys.com)
You made progress in making the exact copy of the picture. By modyfying pyramid geometry or by adding a rectangular block between each pyramid layer is a solution.
Also, as replied in above post please refer this Understanding mesh order for overlapping objects – Ansys Optics to understand mesh order to make hollow pyramid.
thanks and regards
Devika
August 9, 2023 at 7:54 pm
Kawshik Nath
SubscriberThanks, Ms. Devika.
I’m redesign by using the aforementioned methodes. But here also, When i desgned using rectangle winthin the pyramid, I got abnormal result in reflectance curve. i.e, Getting abnormal oscillation in the simulation result.
August 10, 2023 at 5:33 pm
Ansys EmployeeHello,
Can you share more details?
August 13, 2023 at 6:38 pm
August 14, 2023 at 4:15 am
Please try to simulate longer time with smaller autoshutoff min. Also, is it possible to share the screenshot of final geometry also?
Is your simulation single wavelength? please check broadband result and see if the reflection curve is smooth or not.
August 14, 2023 at 7:37 am
Kawshik Nath
SubscriberDo you want to see the screenshoot of FDTD geometry?
August 14, 2023 at 3:40 pm
Ansys EmployeeYes. share a screenshot of final geometry picture. Provide maximum information single response.
I repeat, please try to simulate longer time with smaller autoshutoff min.
I am also suggesting you to set the settings of simulation similar to the example Silicon solar cell with TiO2 pyramid array – Ansys Optics.
Regards
Devika
August 17, 2023 at 6:23 pm
August 14, 2023 at 7:42 am
August 14, 2023 at 7:43 am
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
7742
4502
2961
1449
1322
