How to design Permanent magnet generator in Rmxprt?
    • umozumder
      I got the Ansys Electronics desktop. I am trying to design Permanent magnet generator in RMxprt. But I can not find the option for that. All I am finding is PM DC motors. Could you please help on this regard?
    • Navya C
      Select Adjust-Speed Synchronous Machine
      If you select the control type to AC in the machine settings then you can change the operation type to generator in solution setup.
      Regards Navya
    • umozumder
      Thanks a lot. I am able to work on it. Could you suggest to me how to divide a stator into two separate stators?
    • Navya C
      Can you elaborate on what do you mean by divide the stator into two parts?
      Is it in Maxwell or RMXprt you are asking?
      If you are creating a maxwell model from RMXprt, it will automatically create the smallest possible symmetry model.
      You can control the number of fractions as mentioned in the below forum discussion.
      Regards Navya
    • umozumder
      Hi Thank you for your informative reply.
      Sorry for my ambiguous words. I should have been more specific. I am trying to design a dual stator with some phase differences between these two stator sides. Is it possible to design this type of machine RMxprt? If so, how?
    • sandeepn20
      Could you please tell, What should be done to simulate a full model in Maxwell-2D while creating it from RMxprt design ?
    • Navya C
      Before you analyze the RMxprt model, go to RMxprt > Design settings > User-Defined Data > Check Enable
      In the text window type "Fractions 1" without quotation marks (capital F).
      Then Analyse the RMxprt model andcreate the Maxwellmodel
      Regards Navya
    • sandeepn20
      I am getting this error.
    • sandeepn20
      I am able to fix this issue.
      Maxwell 2D > Mesh Operations > Initial Mesh Settings, and select Classic.This will remove that error message.
      Thanks
Viewing 8 reply threads
