February 15, 2022 at 11:34 pm
Amir_agha
SubscriberDear All,
I have a transient 3D model of a single-phase transformer. To decrease the amount of calculation, I decided to use 2D analysis instead. However, I do not know how to determine the depth of this 2D model. The diameter of the core of the 3D model is 830 mm. I really appreciate it if you can help me to find the answer. Do I have to use 830 mm or 415 mm is enough?
Thank you in advance.
February 16, 2022 at 7:10 amNavya C
Ansys EmployeeHi @Amir_agha Assuming that you are using planar symmetry and taking the model section across the XY plane, you should use the total length of the core along the Z direction as the depth of the model (or symmetry multiplier).
Make sure you use correct units (M, cm, mm)
Regards Navya
February 16, 2022 at 4:16 pmAmir_agha
SubscriberHi Nchode Thank you for your response. So for this case , I have to use 830 mm as the depth of the 2D simulation?
February 17, 2022 at 4:27 amNavya C
Yes, If you have considered symmetry correctly and the model is symmetrical along the Z-axis.
Regards Navya
February 17, 2022 at 10:28 amAmir_agha
SubscriberHi @nchode Thank you for your response.
My 3D model is a symmetric one.
I just realized that I must use 2*830mm (1660 mm) if I want to have the same result for both 2D and 3D simulations.
It makes me confused since based on the same volume of the core (I mean if I want to determine the depth of the 2D model to have the same volume as the 3D model), the depth must be 623mm. However, 623 mm does not give me the correct result.
At this time, I am not sure which one must be selected.
February 17, 2022 at 3:26 pmHDLI
What is the geometry in 3D? If the geometry is rational symmetry, we could use "Cylindrical about Z" in menu Maxwell 2D -> Solution type.
HDLI
February 17, 2022 at 6:22 pmFebruary 18, 2022 at 8:22 pmHDLI
I suggest to use 3D Maxwell to simulate it, and the 2D model will not present it perfectly for inductance and flux density distribution.
HDLI
Viewing 7 reply threads- You must be logged in to reply to this topic.
- Maxwell, HFSS or Q3D?
- Error
3720
2570
1783
1236
594
