How to devide a surface using ICEM CFD ?
    • manelaero2020
      Hi friends
      I am meshing an aircraft. Since the geometry of the aircraft is complicated, it is hard to divide the solid body surfaces in design modeler or space claim (in the order to create a refinement at those surfaces later in ICEM)
      So, the question is: how can I split my surface body in ICEM (for example the wing or fuselage )?
      Can you please join some videos? I have searched but I don't have found a clear easy one ( I am new to ICEM )
      Thank you a lot
      Kind regards
    • Keyur Kanade
      Please create curves at the locations where you want to split the surfaces. Then make sure that you project these curves on surfaces. Then use Segment/Trim surface option.
      If you are new to ICEM, I would recommend you to use SpaceClaim and Ansys Meshing. for aircraft geometry.
      Please go through help manual for more details
      Regards Keyur
    • manelaero2020
      It is ok
      thank you for the advice
