August 15, 2019 at 9:25 pm
wuxuetianzi
SubscriberI am using the UDFs to replace default diffusivity and reaction rate. it is a transient simulation and seems straight forward to getting reaction rate distribution by using 'contours of' under the Results section. but the problem is how to get diffusivity distribution or diffusivity values for different zones at a different time?
Thanks!
August 16, 2019 at 10:11 am
Ansys EmployeeIf it's not in species or properties you may need to use a User Defined Memory in the UDF. Then display that.
2614
2088
1321
1108
459
