November 15, 2020 at 11:40 am
AhmedDesoki
SubscriberDear folks
I want to model a bolted connection. There is a clearance between the hole of upper jointed part and the bolt. Hence, the bolt is expected to carry axial load (tension/compression).
The Ansys Beam connection is supposed to model bolts, but unfortunately, such beam connection carries shear and torsion in addition to the axial load.
November 16, 2020 at 1:38 ampeteroznewman
SubscribernInsert a Probe into the results and select the Joint. You will get tabular data on the forces going through the joint and a vector of the total force in the graphics window.nViewing 1 reply thread- The topic ‘How to display the loads carried by a Body-Body joint?’ is closed to new replies.
Trending discussions- How to do the frequency response of the nonlinear vibration of a flexible PCB?
- Importing Line and Solid Bodies from SpaceClaim to Mechanical
- how to open SendCommand in Ansys
- problems facing during solution
- Still facing the same issue
- Failed to move file from solver directory to scratch directory: file.rst
- Adaptive Sizing
- Stiffness factor
- Import DAT file
- Import pressure data (coordinates and value) to ansys workbench through excel
8808
4658
3151
1680
1470
