March 23, 2021 at 8:12 am
za36kuzo
SubscriberHello everybody,
I am simulating the motion of sand in a narrow pipe. I tried to create the animation, and I keep the autosave of animation for particular time step in the fluent. The problem now after writing a file in the animation playback screen, it was difficult to visualize the motion of the particle, due to the high length to diameter ratio of the pipe (L=1m, D=0.003). I wonder if there is any procedure to visualize the motion of particle in the saved animation file.
Other problem I faced in MPM, after I have created the periodicity in fluent, use the TUI command: define>b-c>m-z>m-p….., I am not able to add the MPM model, using define>mod>add, because TUI still defined with Boundary condition. It is possible to switch off from periodic BC to add MPM model?
Thanks, in advance!
March 23, 2021 at 8:38 amDrAmine
Ansys EmployeeFor MPM better to rely on Fluent Post-Processing the dedicated MPM display functions. Avoid using DPM Post-Processing or External Post-Processing here.nMarch 23, 2021 at 12:37 pmza36kuzo
SubscriberThank you very much for replying, I will try this approach! nAlso, it is possible to switch off from periodic BC to add MPM model using the TUI command?nBest regardsnn nnViewing 2 reply threads- You must be logged in to reply to this topic.
2618
2098
1323
1110
461
