December 7, 2022 at 12:58 pm
javat33489
SubscriberHi all. I want to calculate the volume fraction of one of the phases in a certain domain (for example, a pre-prepared named selection). For example, I have a mixture model of water and gas. I need to know how much gas is in the pipe in kg or as a percentage. I came up with a way but I can't make this variable. Help me. I think it can be rendered like this: volume fraction*density in a specific domain, for example I previously created a named selection called GAS. And then find the integral over the volume of this expression. But how to arrange all this? Help please?
December 7, 2022 at 2:42 pm
Ansys EmployeeAssuming you're using FLuent, have a look in the Volume Reports in the Results section.
December 7, 2022 at 5:07 pm
javat33489
SubscriberBut there is no volume parameter there. Yes, it's FLUENT. Tell me more please?
December 7, 2022 at 5:19 pm
Ansys EmployeeIn the Results section (ribbon) there's a Volume Integrals option. If you want to parameterise that you'll need to create a Report Definition.
December 8, 2022 at 2:34 pm
December 8, 2022 at 2:45 pm
Ansys EmployeeDid you label the cell (volume) zones or the faces? NS are generally passed over, but it's common for people to only label faces.
December 8, 2022 at 2:48 pm
javat33489
SubscriberLooks like I made a surface when I did it in SPACECLAIM. How to make a volume so that I can watch its volume?
December 8, 2022 at 3:05 pm
Ansys EmployeeSplit the volume and label in SpaceClaim. In Fluent you can split cell zones using Registers: not as straightforward but worth learning. It'll be covered on here somewhere.
2524
2066
1279
1096
459
