Topics relate to HFSS, Maxwell, SIwave, Icepak, Electronics Enterprise and more
How to do magnetization in MAXWELL?
    • qiang wei
      I set two models, one for source, the other for target.
      In source model, I set magnetization computation and defined the BH of soft magnet in 1st quadrant. About excitation, the d-axis current was given.
      In target model, I set PM field link to source model, click compute none in magnetization panel, and just give zero in current.
      But it still didnt work!
      How to solve this problem?
      Source model can stimulate properly, but when it came to target model, it went like this:
    • DELI
      hi, does it solve in the source model without linking permanent magnetic field? Which solver is used in both design?
      • qiang wei
        In source model, there is no linking to permanent magnetic field. Only in target one, the PM is linked to sourcr model.
        What is solver mean, you mean solution type?I use Magnetic Transient for both of them
        • DELI
          Thanks for the additional info, please refer technotes "Using the Hysteresis Model-Based Demagnetization/Magnetization Approach (Transient Solver Only)" on Maxwell Help Manual.
        • qiang wei
          I did refer the notes "Using the Hysteresis Model-Based Magnetization Approach" (cause I only wanna do magnetization other than demag.), but I dont konw what is the input Hc means (red marked tests)?
          I selected the Hysteresis Model, do I need to input value of the Hci here?
        • DELI
          Yes, you will need Hci value here for the hysteresis model based method. Usually this data is provide by vendor, or you can bring this to test in certified labs.
        • qiang wei
          I just trid use Hysterisis Model of the material, and set as below:
          Unfortunately, still didnt work, and said like this:
        • DELI
          Please refer to the technotes "Using the Hysteresis Model-Based Demagnetization/Magnetization Approach (Transient Solver Only)" from Maxwell manual, it has step by step instructions for both source and target designs.
        • qiang wei
          The technotes say there will be three models for this, but doesnt say how to set the excitation, I mean how to set the current excitation in each model?
          Now I give the current pulse excitation in the fisrt two source model, and set zero excitation in the target one.
