August 22, 2022 at 8:07 pm
jnranhil
SubscriberHello,
I have created a CAD model using Ansys Spaceclaim. I used an equation to design it. I need to draw the technical drawing of it (2D drawing). How can I do the dimensioning of the equation-driven curvature? The shape of the curvature is not a standard circular curvature.
Thank you so much for any help.
Best,
Ranhili
August 23, 2022 at 4:22 am
Keyur Kanade
Ansys EmployeePlesae check Details tab. It has different options for dimentions.
Please go through help manual for more details
Keyur
August 23, 2022 at 4:25 am
August 23, 2022 at 6:27 pm
jnranhil
SubscriberHi Keyur,
I have used the Details tab for creating tech drawings. The issue I have here is, that the design that I have right now is, an equation-driven design. It is not a standard shape. So I want to do the dimensioning for that. Can you advise more specifically on that, please?
Thanks for your time,
Ranhili
August 24, 2022 at 4:54 am
Keyur Kanade
Ansys EmployeeIn that case you will need to custom anotations.
Keyur
August 27, 2022 at 3:35 pm
SubscriberMany manufacturers can create parts from the solid model of the design. The tool paths are programmed directly off the solid geometry. They don't need the drawing to create the shape of the part. The drawing only adds information that is not geometry such as material, surface finish, datums and tolerances.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2524
2066
1285
1096
459
