August 11, 2019 at 3:10 pm
pssjn
SubscriberMy study is to find out the air ventilation rate inside the room. So I need to find out the air pressure and velocity on the windows.
My queries are:
How do I draw an Atmospheric domain with the room inside?
How do I define the boundary condition of both the domain and room?
I need to produce the following images.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2508
2064
1277
1088
456
