February 7, 2021 at 9:04 pm
victor13165
SubscriberHello,nI'm using SpaceClaim to model a Vertical Axis Wind Turbine (VAWT) in 2D. All the calculations went fine and I was able to get everything I needed to.nHowever, I thought I would modify one of the diameters of the main axis, but when coming back to SpaceClaim I noticed I couldn't go back to the original sketch that was used to generate the 2D surface on which I performed the calculations. nThis works on DesignModeler, I can easily see the sketch I used to generate the surfaces, etc. In SpaceClaim, whenever I generate the surface, the sketch instantly disappears.nAm I doing something wrong?nThanks in advance for the helpnPS: I'd be happy to provide screenshots or further explanations if needed.nn -
February 8, 2021 at 4:37 am
Keyur Kanade
Ansys EmployeeYou can use Pull or Move tools to modify your 2D geometry dimensions. nPlease go through help manual for more details nYou can also find few videos on Pull and Move on youtube. nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
- check element type
- Meshing Error
- Error in meshing
- How to resolve Mesh Failure
5340
3345
2471
