June 30, 2020 at 4:52 pm
MichaelDelle
SubscriberDear Sir/Madam
My question is, how can I make sure that thew core is correctly connected to the face sheets? For 22 bodies I get 14711 Nodes and 16388 Elements but when I opt to use contacts I cant really figure it out.
Additionally I want to add a layer of Epoxy resin between the core and the faces. Should I just design an extremely thin sheet body and just appoint through material selection the Epoxy resin ? Or in the analysis settings should I just choose the surface coating method ?
I know that because of the high modulus of elasticity I can avoid it but I will be doing a thermal stress analysis with a thermal cycle of -+ 120 degrees C so I want to check how it will operate and affect my model.
And this is the connections:
Please let me know if anyone knows what I should look for exactly.
Kindly,
Michael
July 6, 2020 at 5:25 pm
Aniket
Ansys Employee1. You can use bonded contacts between edges of the honeycomb structure and face sheets or you can keep them in a multibody part and use shared topology like you have used for the "part" in the geometry without using any contact
https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v195/wb_sim/ds_Surface_Models.html
2. I think you can use layered section as mentioned in the link above here.
-Aniket
July 15, 2020 at 2:38 pm
MichaelDelle
SubscriberDear Mr Aniket,
thank you for your answer. I will be soon testing that.
Kindly,
Michael
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
3648
2520
1745
1226
578
