how to enter pressure value as zero
    • harishkamath86
      hii,
      in this image, as mentioned, I have to apply zero pressure on four faces and on the top face, I have to apply rotational speed of 2000 rpm. but facing a problem with this. kindly help to apply boundary conditions for my CFD analysis. what are the boundary conditions I have to apply to solve this?. Thank you.
      kindly help
       Boundary condition
      Try setting the motion on the fluid cell zone and then use pressure boundaries. I assume you mean zero gauge pressure? What's the ambient pressure?
    • harishkamath86
      Thank you for your kind reply sir.
      Sir, you are right. I want to apply zero gauge pressure on all the four faces of fluid and rotation for the top layer of the fluid face.
      rotation I am able to give on the top face but I don't know how to apply zero gauge pressure to those four faces.
      Sir, what kind of pressure boundaries I have to apply? pressure inlet and pressure outlet on four faces ??
      Sir, I need to get pressure results like this, as per the boundary conditions mentioned earlier
      thank you
      kindly reply
    • DrAmine
      Are the 4 faces areas where flow might enter or exit? Or walls?
    • harishkamath86
      enter from only one face and exit from opposite side face. to be specific, enter from the left side and move towards the right side
      if all four faces are specified as "wall" then whether gauge pressure will be zero ??
      thank you
    • DrAmine
      No: with walls it won't work the way you want.
      Now why does enter from one side and leave from particular side?
    • harishkamath86
      Dear Amine Sir, Kindly excuse for the last message.
      ( Sorry for the last message where I said it enters from one end and leaves from other)
      As per the published literature, actually fluid is restricted to stay within that confined boundary. It builds-up pressure on the solid body which is present below it.
      Sir, neither fluid leaves from any of the sides nor enter.
      Sorry again.
      Thank you
    • DrAmine
      Then walls. Read carefully the paper as at walls you cannot provide pressure information.
    • harishkamath86
      Dear Amine Sir,
      if I specify "Walls" as BCs then I am getting wrong results. I am getting pressure variations at the boundary of the fluid. I am not supposed to get pressure variations near the boundary.
      Finding difficult to solve this.
      Sir, any other solution?
      Thank you for kind reply
    • DrAmine
      No I do not have any other solutions. The only one quick thing is using pressure outlet with zero absolute pressure there but this might allow flow getting out of these boundaries.
Viewing 9 reply threads
